BKCruizers
Would you like to react to this message? Create an account in a few clicks or log in to continue.
adjustable pushrod tubes ???????
4 posters
adjustable pushrod tubes     ??????? Empty adjustable pushrod tubes ???????
Post  sploval53 Wed 12 May 2010, 2:05 am
okay i have two push rod tubes that are leaking like crazy and i really don't want to take the motor out of the gray car to switch them out what adjustable pushrod tubes don't leak like crazy anyone have any ideas
http://www.myspace.com/quickyistheshit
adjustable pushrod tubes     ??????? Empty Re: adjustable pushrod tubes ???????
Post  Kx3 Wed 12 May 2010, 10:01 am
They all suck ..... I have never had any luck with those , sooner or later they will leak ......
Post  Mountain Power House Wed 12 May 2010, 10:35 am
Go ahead and bite the bullet.. Pull it out and replace them, otherwise all you'll have is more problems.
http://www.aircooledtechnology.com
Post  Mohawk Wed 12 May 2010, 5:34 pm
I bought some adjustable pushrod from JayCee. They was not to bad. The best one I ever used is manufactured by a good friend to me. Looks like the same JayCee does but with S.S rings and spring. The o-rings are in viton that is more heat resistant.
adjustable pushrod tubes     ??????? Sljes_10
http://mohawk-vw.blogspot.com/
