Fuel pumps
Fuel pumps
Post  VOLKSWAGENUT on Sun 27 Jul 2008, 10:20 pm
Ok guys whats the popular fuel pump , I was running a normal little fuacet square electric pump. Think its junk! what chew running? best type? brand?
Re: Fuel pumps
Post  overspray on Sun 27 Jul 2008, 10:27 pm
Holley Blue.....
But Facet is a good pump, where you have it mounted?
Re: Fuel pumps
Post  Kx3 on Sun 27 Jul 2008, 10:58 pm
Put a stock pump back on it ...... It will run just fine & easy to replace if you have to do it on the side of the road .....
Re: Fuel pumps
Post  VOLKSWAGENUT on Sun 27 Jul 2008, 11:02 pm
Kx3 wrote:Put a stock pump back on it ...... It will run just fine & easy to replace if you have to do it on the side of the road .....
Fuel injection case....... no hole for it. Embarassed
Re: Fuel pumps
Post  mrclean on Sun 27 Jul 2008, 11:04 pm
i use a CB rotory pump works just fine.
Re: Fuel pumps
Post  VOLKSWAGENUT on Sun 27 Jul 2008, 11:05 pm
overspray wrote:Holley Blue.....
I had it mounted under by the trans. with a fuel filter after it. and a pres. regulator.
Re: Fuel pumps
Post  mrclean on Sun 27 Jul 2008, 11:08 pm
with a CB rotory pump you don't need a regulator.
Re: Fuel pumps
Post  Kx3 on Sun 27 Jul 2008, 11:10 pm
Ah yes the ever popular FI case ........ Laughing The CB pump in Bills car seems to work great and its quiet ....
Re: Fuel pumps
Post  VOLKSWAGENUT on Sun 27 Jul 2008, 11:27 pm
cool guys thanks for the help . do you think the location is ok , under buy the trans? where is yours? I never had trouble with it under there.
That CB pump is a cb performance pump . right . Laughing
Re: Fuel pumps
Post  Tanbug on Sun 27 Jul 2008, 11:37 pm
Change cases.....use stock pump.
While you're in there, change the crank. What a Face
Re: Fuel pumps
Post  mrclean on Mon 28 Jul 2008, 12:27 am
mine is located under the gas tank..
Re: Fuel pumps
Post  overspray on Mon 28 Jul 2008, 12:38 am
Should be up front pushing...
I'm going wiff the CB pump next time...Mine is loud..like thinks are falling off... like when I was driving Bills car..... Razz
Just carry an extra pump wiff gator clips so you can hook it to the coil and keep on drivin next time.... You know everything last longer on a trailer... tongue
Re: Fuel pumps
Post  VOLKSWAGENUT on Mon 28 Jul 2008, 12:55 am
I will try to move it up front see if that works better. What pressure shoud i set the regulator at? about 2.5 ? reg. up front to? I think the heat of the motor has something to do with it also. cause it was going good in the morning and then afternooon when hot it was bad. should fix that up front.
Re: Fuel pumps
Post  Cave Man on Mon 28 Jul 2008, 12:57 am
CB kit is has Carter rotery pump in it. You can get the same one from Summit. Smack has a good part # for the carter. I have got the # here somewhere. Ill look for it.
Re: Fuel pumps
Post  VOLKSWAGENUT on Mon 28 Jul 2008, 1:00 am
Cave Man wrote:CB kit is has Carter rotery pump in it. You can get the same one from Summit. Smack has a good part # for the carter. I have got the # here somewhere. Ill look for it.
Cool thanks.
Re: Fuel pumps
Post  Cave Man on Mon 28 Jul 2008, 1:18 am
http://store.summitracing.com/partdetail.asp?autofilter=1&part=CRT%2DP60504&N=700+4294836965+115&autoview=sku
Try this link it it to a carter pump.
Not sure its the same as the CB kit but I thinks its the one. Im still lookin for the # I got from smack.
Re: Fuel pumps
Post  VOLKSWAGENUT on Mon 28 Jul 2008, 10:09 pm
found this on samba , in a thread. same part numnber as above.
That Carter Rotary Fuel Pump can be bought at any local NAPA Auto Parts store. Just ask for PN: P60504. Got mine out the door for $60.00.
Re: Fuel pumps
Post  POKER on Mon 28 Jul 2008, 10:27 pm
I use a fuacet square. It needs to be mounted beside the gas tank. It's a pusher not a puller.
POKER
In & out
Re: Fuel pumps
Post  Mountain Power House on Mon 28 Jul 2008, 11:23 pm
The Facet and most other pumps are better "pushers" than "pullers', meaning they need to be placed under the tank and as close to it as possible.
I carry the same rotary pump that CB has and it has proven good clear past 200HP on my dyno..
View user profile http://www.aircooledtechnology.com
Re: Fuel pumps
Post  VOLKSWAGENUT on Tue 29 Jul 2008, 5:04 pm
Mountain Power House wrote:The Facet and most other pumps are better "pushers" than "pullers', meaning they need to be placed under the tank and as close to it as possible.
The one you have does it need a presure reg. If so you sell them right? How much are they , I may need to get one. Very Happy Gonna re mount it up front and thought about getting one that needs no reg. Easier to mount and less junk to worry about.
Re: Fuel pumps
