Ennis Tx - Big Bug Shootout Oct 04
Post  Noh2o on Tue 22 Sep 2009, 11:29 pm
Show and Drag races at texas motorplex.
show features $250 best of show win with all other best of's and 1st winning money (100 - 50) respectively. Drags payout based on car count.
good show with great cross section of cars and people.
I know , conflicts with CYW.
Noh2o
Re: Ennis Tx - Big Bug Shootout Oct 04
Post  Fusillade on Wed 23 Sep 2009, 8:32 am
All my parts came in yesterday. If I can get my car ready in time, I plan to attend this show.
Fusillade
Post  overspray on Wed 23 Sep 2009, 8:43 am
What you doing to it ? do tell ?
Post  Fusillade on Wed 23 Sep 2009, 5:21 pm
overspray wrote:What you doing to it ? do tell ?
No major changes just yet. Still working to get it to pass inspection while working 60+ hours at work. Muffler, tag light, horn, parking light, blinkers, emergency blinkers, wipers, side mirror, and dash lights.
So far, rewired the blinkers and repaired dash lights. Rewiring the right front parking light, left front ground, and tag light later this evening. Then it is on to the wiper assembly.
Fusillade
Post  Thang on Wed 23 Sep 2009, 10:56 pm
Anything on that car that DOES work? Suspect Suspect Suspect Suspect lol!
Post  overspray on Wed 23 Sep 2009, 11:37 pm
Damn..how hard did you hit that bridge....so you wired the turns to 12 volt ?? all lights cept taglight worked scratch ....and wipers work..even has a 12 motor...
Post  Fusillade on Thu 24 Sep 2009, 12:20 am
overspray wrote:Damn..how hard did you hit that bridge....so you wired the turns to 12 volt ?? all lights cept taglight worked scratch ....and wipers work..even has a 12 motor...
I hit so hard it knocked the gas tank loose and it felt like someone had...
With the 145/65/15s on the front, clearance is down to 2 3/8".
Yes, the turn signals are now 12V. I got a new assembly for the tag light so I will just need to locate or run a new wire. I'm not sure what is wrong with the wipers just yet. I should have it all fixed by this weekend.
Fusillade
Post  overspray on Thu 24 Sep 2009, 8:46 am
DAMN ! The tag light wire plugs in the harness on the lower right side on engine compartment. Ck the wiper fuse, only prob. i had with them was they were so fast on high they would rotate on the shaft if it wasn't real tight...... Yup those tires are low...
event date moved
Post  Noh2o on Fri 02 Oct 2009, 11:19 pm
Event moved to OCT 18 due to weather coming in...
Noh2o
