RECYCLED AIR
+6
highbacksrule
10 posters
Page 1 of 1
RECYCLED AIR
Charels why the Turbo? I thought you took pride in Real Motor Performance? now your using a crutch to run fast? Lame
highbacksrule- Posts : 43
Re: RECYCLED AIR
highbacksrule wrote:Charels why the Turbo? I thought you took pride in Real Motor Performance? now your using a crutch to run fast? Lame
sounds to me like he is getting smarter less money and more power
TURBO- MR hub caps
Re: RECYCLED AIR
TURBO wrote:highbacksrule wrote:Charels why the Turbo? I thought you took pride in Real Motor Performance? now your using a crutch to run fast? Lame
why should charles go turbo when i whipped your ass and he is slower than me.
mrclean- 2nd highest HP
Re: RECYCLED AIR
mrclean wrote:TURBO wrote:highbacksrule wrote:Charels why the Turbo? I thought you took pride in Real Motor Performance? now your using a crutch to run fast? Lame
who took your money
TURBO- MR hub caps
Re: RECYCLED AIR
TURBO wrote:mrclean wrote:TURBO wrote:highbacksrule wrote:Charels why the Turbo? I thought you took pride in Real Motor Performance? now your using a crutch to run fast? Lame
who took your money
not you big boy another all motor car.
Re: RECYCLED AIR
do you not remember are bet?
TURBO- MR hub caps
Re: RECYCLED AIR
TURBO wrote:do you not remember are bet?
yup i broke. but there will be a next time.
Re: RECYCLED AIR
mrclean wrote:TURBO wrote:do you not remember are bet?
I cant wait
TURBO- MR hub caps
Re: RECYCLED AIR
next time i will not go easy on you
TURBO- MR hub caps
Re: RECYCLED AIR
overspray- Papa bear
Re: RECYCLED AIR
just to clear the air, my engine is a 2110 not something else as some people think(trooper or highbacks rule or whatever you call yourself) im sorry that you cant make power and have to make up shit on other people, if you had listened to me before on porting you could have been there with some good numbers! maybe next year!
fluffy- Posts : 13
Re: RECYCLED AIR
fluffy wrote:just to clear the air, my engine is a 2110 not something else as some people think(trooper or highbacks rule or whatever you call yourself) im sorry that you cant make power and have to make up shit on other people, if you had listened to me before on porting you could have been there with some good numbers! maybe next year!
Ran like a 1915....... But I know a guy that can get you some real power outta those heads...
pretty good with Valve guides too....
Re: RECYCLED AIR
Somebody showed up to get all tender .
Cave Man- Posts : 367
Re: RECYCLED AIR
okay let's clear the air (at least get the shavings out of the air) let"s see... you had a 82 crank, then it broke, you ordered another "82" crank, and then you had to spend time to open up your case for the same size crank. must have been one of those new and improved "beefy" cranks. lolfluffy wrote:just to clear the air, my engine is a 2110 not something else as some people think(trooper or highbacks rule or whatever you call yourself) im sorry that you cant make power and have to make up shit on other people, if you had listened to me before on porting you could have been there with some good numbers! maybe next year!
Re: RECYCLED AIR
Got to study on that.
Big Beef Crank. It must be "Custom Made" More Rotating Mass to get the car to launch better.
Re: RECYCLED AIR
highbacksrule wrote:okay let's clear the air (at least get the shavings out of the air) let"s see... you had a 82 crank, then it broke, you ordered another "82" crank, and then you had to spend time to open up your case for the same size crank. must have been one of those new and improved "beefy" cranks. lolfluffy wrote:just to clear the air, my engine is a 2110 not something else as some people think(trooper or highbacks rule or whatever you call yourself) im sorry that you cant make power and have to make up shit on other people, if you had listened to me before on porting you could have been there with some good numbers! maybe next year!
just to let some of you newbie's know that have never built your own motors that from different crank manufactures the counterweights are larger than other's so maybe thats why fluff had to do some more grinding. don't be mad you don't know anything about making power. BTW if someone took my motor apart with out asking me before hand they would be getting a serious ass wooopin.
Re: RECYCLED AIR
LOL Nobody tore fluff's motor down. wouldn't do a brother like that. built my own motors, don't trust fluffy'smrclean wrote:highbacksrule wrote:okay let's clear the air (at least get the shavings out of the air) let"s see... you had a 82 crank, then it broke, you ordered another "82" crank, and then you had to spend time to open up your case for the same size crank. must have been one of those new and improved "beefy" cranks. lolfluffy wrote:just to clear the air, my engine is a 2110 not something else as some people think(trooper or highbacks rule or whatever you call yourself) im sorry that you cant make power and have to make up shit on other people, if you had listened to me before on porting you could have been there with some good numbers! maybe next year!
Page 1 of 1
