Your engine specification/components
Post  Mohawk on Wed 12 Nov 2008, 5:20 pm
I will put together a new engine to the next summer i hope. I'm a little curious what you guys have in your engines. I put up a list so you can copy.
  • Case, New aluminum or stock magnesium AS21 style, manufacture
  • Crank shaft, manufacture, model and size
  • Rods, manufacture, model and length
  • Piston and cylinder, manufacture and size
  • Cylinder heads, manufacture size on valve springs, cylinder compression
  • Push rods, manufacture and material
  • Rockers, manufacture and ratio
  • Camshafts, manufacture and model
  • Lifters, manufacture and model
  • Oilpump, manufacture and model
  • Carburettor, manufacture, model and size on venturi
  • Exhausts, manufacture, model and size on the pipes
Maybe have I forgot something, but if you know something funny or interesting that I have missed just continue on the list.
Re: Your engine specification/components
Post  Mohawk on Wed 12 Nov 2008, 5:57 pm
Stock AS41 from 73
Stock 69mm
Stock
Cima, Mahle 92mm
041 heads with 40x35,5 dual springs, 11,1:1
Chromoly Tapered
Stock with bolted ends
Eagle 110
Racing lifters
meling 30mm
Misab intake amnifolds with Dellorto 45. 38 in venturi
S&S racing 1 5/8 with home made muffler.
Post  overspray on Wed 12 Nov 2008, 8:29 pm
Mohawk wrote:I will put together a new engine to the next summer i hope. I'm a little curious what you guys have in your engines. I put up a list so you can copy.
    AS41 full flowed and welded @ #3 CM head studs bored and deck, clearenced case.....
    Scat 82 mm with CB strait cut gears and race spacer and scat 40mm gland nut
    5.5 Scat I beams
    Cima 94 mm notched for valve clearence, Total seal rings
    CB street eliminator 94 bore 44x 37 SS valves chevy springs....match ported intakes. massive head work by Pro Flow performance for making more power than Mr clean per CC's
    Chrome moly ....Spring loaded scat race tubes
    Scat 1.5
    FK89...
    Scat lub-a-lobe
    shadek
    weber 48 IDF worked by Art... 42 mm vents
    13/4 new style A-1 with SS muffler
1 1/2 sump
MSD with Summit dig. box
welded fan
copper disc.
Type 4 oil cooler
Cow Magnet
Post  mrclean on Wed 12 Nov 2008, 9:11 pm
[quote="Mohawk"]Case, New aluminum or stock magnesium AS21 style, manufacture
Stock AS41 from 73
aluminum high roof
scat 84
scat 5.7
Cima 94's
cb cnc comp eliminators 48x38 12.1.1 comp
Chromoly Tapered
cb 1.4
Eagle fk47 630 lift at the valve
cb light weight lifters
shadek 28mm
weber 48 IDA'S 42 vents done by art thran
A-1 1 3/4 with muffler
Post  TURBO on Wed 12 Nov 2008, 9:45 pm
I have TURBO......................... that is all you need Very Happy Very Happy Very Happy
Post  VOLKSWAGENUT on Wed 12 Nov 2008, 10:04 pm
TURBO wrote:I have TURBO......................... that is all you need Very Happy Very Happy Very Happy
Laughing
Post  Tanbug on Thu 13 Nov 2008, 11:50 am
CB Performonce super case, full flow
CB 82mm forged
CB super race, 5.5
Mahle 90.5
DRD L-5 built on CB 041 heads. 8.7:1 compression
EMPI Embarassed cromoly
Rhino 1.1:1 on Scat solid shafts
Web Cam 122/125....supplied by DRD
Suppiled by DRD
Berg full flow, Schadek pump
Weber 44, 36 vents
A-1 lowdowner 1 5/8 ceramic
Pretronix ignition system w/ digital rev limiter
T-4 oil cooler
Lightened flywheel & heave crank pulley
Straight cut cam gears
Post  yellow73 on Sat 22 Nov 2008, 12:27 pm
I think I might get in trouble if I responded since I would be using the words Type IV frequently!!!!! - I am worried that the site might implode if I were to post such information here although I did notice that Overspray has a Type IV oil cooler!!!!
yellow73
Post  Hobug on Sat 22 Nov 2008, 12:35 pm
I'll say it Nigel. I'm running a 2L Type 4 with Dell 40s and one of Jake's headers. Type 4, Type 4, Type 4.......
I love it. shifting
Hobug
View user profile http://www.athensvwclub.com
Post  overspray on Sat 22 Nov 2008, 12:40 pm
Dang Hobug..I missed that @ bug Jam..where was it ? Razz
Post  Hobug on Sat 22 Nov 2008, 2:10 pm
It was on vacation in my garage. Even a daily driver gets time off now and then. Cool
Hobug
Post  Tanbug on Sun 21 Dec 2008, 1:36 am
Rolled up 11,000+ miles on the 68 this year.
Christmas tune-up time. What a Face
Post  Mohawk on Sun 21 Dec 2008, 8:32 am
Tanbug wrote:Rolled up 11,000+ miles on the 68 this year.
How is that possible? scratch
Do you have some kind of rollers that spin your front wheel on the Bug when it's loaded on your queen trailer, driving around ?
I guess it must be OK if you just change the ball bearing on the front wheels. That is the only thing that have bin used.
Post  overspray on Sun 21 Dec 2008, 11:19 am
He has 2 1/2 VW's Hawk.. BK car ....Driver.... and Fat chick Vert.!
