Good & Bad
+7
cousin of a porsche
11 posters
BKCruizers :: BUY-SALE-BUILD :: TECH
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Good & Bad
The Good.....Super diff good
[img][/img]
The Bad.......Ring & pinion crunchies
[img][/img]
Time to learn how to fix a trans.....
[img][/img]
[img][/img]
Re: Good & Bad
that sucks... thats probly what mine looks like.
mrclean- 2nd highest HP
Re: Good & Bad
OS you rekin you got enough HP to do that to yours?
Cave Man- Posts : 367
Re: Good & Bad
6 n one summer..then I bought a good tranny... and went IRS.. should have been IRS when I was changing swings...
overspray- Papa bear
Re: Good & Bad
Oh OK nowI see why you dont drive your car. Broke it 6 times in a year, maby you should get some training on how to drive a stick shift.
Re: Good & Bad
Bad combo ...Big motors ...lil tranny =empty wallet... you'll see someday when you step up...
Re: Good & Bad
Baby Steps for me. saves on the wallet
Re: Good & Bad
But babies learn to walk before two..you been doing this 12 +years.... don't be a Poker... step up
Re: Good & Bad
OK give you that. But I like my lil Motor and bangged up car. But I will step Up BIG if you will fund the project, How about it?
Re: Good & Bad
Time to learn how to fix a trans..... [/quote]
When you learn can you fix mine?
cousin of a porsche- Posts : 75
Re: Good & Bad
Sounds good. I just need to get the "C" clip back on the pinion shaft in the nose cone. I took off the cone (good thing) and the c clip fell out along with the inner part of the bearing. The bearing is fine but I can't get the inner part in far enough to get the clip back on.
Re: Good & Bad
I'm hoping to get my tranny back in tonight. My 11 tooth spider gears came out with four teeth each.
Fifty - Five- super tender
Re: Good & Bad
cousin of a porsche wrote:Sounds good. I just need to get the "C" clip back on the pinion shaft in the nose cone. I took off the cone (good thing) and the c clip fell out along with the inner part of the bearing. The bearing is fine but I can't get the inner part in far enough to get the clip back on.
Yup I told bill that c clip fell off when he was burning up your tires... But would he listen...
Re: Good & Bad
but the burn out look great.
Re: Good & Bad
sploval53 wrote:How long is that rebuild going to last TAN
See what I need, price it out, then save up.
Re: Good & Bad
Fifty - Five wrote:I'm hoping to get my tranny back in tonight. My 11 tooth spider gears came out with four teeth each.
Custom Waffle House Gears.
Re: Good & Bad
Pinion depth on that trans was incorrect and more than likely the preload was too loose as well...
Trannys are a different level than engines... Loose certainly isn't good!
let me know if you need help.
Re: Good & Bad
sploval53 wrote:hey cave how did that hood work out 4 you
Got it to the cave and thats as far as I have made it. may be lettin go of that car before long.
It may be going on the other car.
Re: Good & Bad
This time, I will start at the rear tortion bars & work toward the trans. No doubt the diff was not shimmed correctly when installed......I learn from most of my mistakes.
Re: Good & Bad
sploval53 wrote:what cave you are getting rid of Ruby
Not a day to soon...damn late model sheet....
Similar topics
» Good price !!!!
» Good news, Mr. Clean
» Good guys show Jun 29, 30, July 1, 2007
» Good "NICE" Bumpers
Page 1 of 3
